查看: 3773|回覆: 32
[分享] 匯總一下Q10PRO Android 5.1 升7.0資訊
發表於 2017-12-16 00:58:23 | 顯示全部樓層 |閱讀模式
您需要 登錄 才可以下載或查看,沒有帳號?註冊
本文章最後由 6hzzz 於 2017-12-16 01:16 編輯
匯總一下Q10PRO Android 5.1 升7.0相關資訊,希望對有需求的人有幫助.
官方http://www.himediatech.com/support.htm給出的:
先刷:
Q10 Pro
(Android L to Android N)
HMD-2.0.4 2017-07-05.191425
720M
再刷:
Q10 Pro
(Android N to Android N)
HMD-2.0.6 2017-10-25.164125
636M
http://www.mediafire.com/file/sgwbfs3gqnduwf7/update.zip for Q10 Pro is used to upgrade from Android L OS to Android N 2.0.4 (Android L to Android N)
Firmware Upgrade by Recovery Mode (user data will be cleared)
1.Download a new firmware and place the firmware onto the ROOT directory of a USB drive.
2. Plug the USB drive into an empty USB HOST on the SMART TV BOX.
3.With the SMART TV BOX turned off,use a paper clip or pen point to press and hold the small pinhole restore button on the SMART TV BOX
4.While pressing the restore button,turn on the SMART TV BOX. Continue to hold the restore button for 5 more seconds,then release it.
5.The SMART TV BOX will begin upgrading the firmware from the USB drive.
6. Wait for the SMART TV BOX to complete the upgrade. Please be patient as it may take around 5 minutes to complete.
7. When finished, The SMART TV BOX will auto reboot.
刷機方法:
強刷模式:
拷貝第一個包update.zip(HMD-2.0.4 2017-07-05.191425)到USB隨身碟根目錄,插到機器左邊第一個USB2.0口.
頂住機器後面的UPGRADE/restore小按鈕後,通電開機,直到看到刷機畫面鬆手.正常升級的情況下耗時大約5分鐘左右.
升到2.0.4後,再採用同樣的方法升到最新的2.0.6(HMD-2.0.6 2017-10-25.164125).
www.futeko.com給出的:
Migrate from Android 5.1 to Android 7
1. Extract update.zip (using an unzip program like 7zip, winzip etc) from Q10_PRO_ANDROID_5.1_TO_ANDROID_7_MIGRATION_FIRMWARE.zip to the root of a FAT32 formatted USB pen drive. (the USB pen drive should contain a single file called 'update.zip').
2. Insert the USB pen drive into any USB port of Q10 Pro.
3. With Q10 Pro turned off, use a paper clip or pen to press and hold the the pinhole UPGRADE button on the back of Q10 Pro (next to the power port).
4. While keeping the UPGRADE button pressed, turn on the Q10 Pro.
5. Q10 Pro will show the Android 5.1 green droid upgrade logo.
6. When you see the Android 5.1 green droid logo you can release the restore button.
7. A progress bar will indicate update progress. Do not turn box off or use the box/remote during update!
8. When update is complete the box will automatically reboot.
9. First boot will take 3-5 minutes. The box will reboot into Android 7 migration firmware. Allow boot to complete.
Download: http://www.mediafire.com/file/r55t37rs732033s/Q10_PRO_ANDROID_5.1_TO_ANDROID_7_MIGRATION_FIRMWARE.zip
Q10 PRO RUNNING  ANDROID 5.1 FIRMWARE VERSION 1.0.7 - 1.1.0:
http://www.mediafire.com/file/bzd7e7vi9bbwz6a/Q10_PRO_FIRMWARE._ANDROID_5.1_TO_ANDROID_7_v2.0.4._FUTEKO._HMD-2.0.4_2017-07-05.191425.zip
刷機方法
先要解壓出update.zip刷機包,其餘跟官方刷機方法一樣.
僅適用Q10PRO版,大陸版Q10四代跟Rocktek版 Q10 Pro都不能刷.如果刷官方包不成功,就試試futeko的包吧.
發表於 2017-12-16 08:34:09 | 顯示全部樓層
測試安裝狀況,Android 5.1 to Android 7升至 2.04版本後,連nas正常,裝完選單補丁後原來不能播的"愛國者行動"可以正常播放了,但沒測試原選單部份就升 2.06(這部份要注意隨身碟要格式化為fat32才行),裝完 2.06後nas就進不去了,有時可以看到nas機器,但就是連不進去,有時就根本沒顯示nas,目前想降回2.04版本卡關中,有知道的說一下吧,感謝先。
回覆 支持 反對
發表於 2017-12-16 10:00:41 | 顯示全部樓層
依 Q10 PRO 專版 746樓連結,下載更新後回到1.08,再更新回2.04,仍然無法連進我的NAS,看來有nas需求的人目前無解了,真是傻眼啊,搞那麼久又回到原點。
回覆 支持 反對
發表於 2017-12-16 14:05:01 | 顯示全部樓層
連nas失敗,但連電腦播放目前沒問題,有藍光原選單跟簡易選單可用,聴說還支援特效字幕了,總的來說還是不錯的,希望連nas部份可以有解決。
回覆 支持 反對
發表於 2017-12-16 20:26:58 | 顯示全部樓層
我終於連上我的nas了,使用自動搜尋始終沒能找到nas,之前因為手動輸入時有錯誤,導致被nas禁連,從nas排除後目前快樂使用中,現在就差我心目中的海報牆了。
回覆 支持 反對
發表於 2017-12-20 20:26:05 | 顯示全部樓層
本文章最後由 antony720 於 2017-12-20 20:29 編輯
剛剛照著~ 6hzzz 大 ~的方法刷新了之後....果然可以正常看4K UHD..連ISO檔也可以播... ya..Q10 PRO 大復活..
感謝 6hzzz 大....^__^y...
回覆 支持 反對
發表於 2017-12-23 23:14:09 | 顯示全部樓層
我一直很想問,之前跟團購買的海美迪Q10 Pro,能不能刷Rocktek的韌體?
不然感覺好像沒辦法再升級韌體,還是這篇文章就是Q10 Pro的最新韌體呢?
回覆 支持 反對
發表於 2017-12-27 14:30:16 | 顯示全部樓層
各位精研板友大家好,
RockTek台灣版Q10 PRO將會提供Android 7.0韌體升級,
包含搞定UHD原盤以16:9比例自動適應播放功能...等等問題,
此更新未來會先以提供韌體給使用者自行刷機來更新,
但由於原廠仍在如火如荼修正韌體所以還需要一些時間,
目前時間預計大概會在1月中左右,請各位關心RockTek Q10 PRO台灣版的板友再耐心等待一下,
謝謝!
回覆 支持 反對
發表於 2017-12-31 12:37:20 | 顯示全部樓層
請問更新後q10pro 變英文介面不知如何改回中文介面?
回覆 支持 反對
發表於 2017-12-31 15:11:45 | 顯示全部樓層
感謝您 6hzzz大大,更新到2.06版 可以播UHD了。
正如樓上版有所說,還是英文版(期望有中文版),不過已很爽了。(還可外掛srt字幕)
還有個困擾問題 :  電源一直關不掉(電視影像關了),但是電源燈(白燈)還亮著,只好拔電源。
回覆 支持 反對
發表於 2017-12-31 20:02:48 | 顯示全部樓層
按方向鍵到設定後進入,往下拉到文字跟語言進入,改按遙控器上鼠標鍵到+鍵去新增語言,下移到繁体中文,新增後會同時有英文跟中文,這裡我也卡關了搞很久,後來直接把英文殺掉就變中文了(這裡要殺英文也弄了好一下子,滑鼠跟按鍵要換來換去,搞不定的再說一聲)。
回覆 支持 反對
發表於 2017-12-31 20:36:47 | 顯示全部樓層
更新後,遙控器無法使用,KODI 17.1的介面實在不會設定,請教樓上諸位大大。哪裡有教學文呢
回覆 支持 反對
發表於 2018-1-1 14:19:47 | 顯示全部樓層
小六子 發表於 2017-12-31 20:02
按方向鍵到設定後進入,往下拉到文字跟語言進入,改按遙控器上鼠標鍵到+鍵去新增語言,下移到繁体中文,新 ...
謝謝小六大,這關也搞得灰頭土臉,老半天就是搞不定,還是英文版。
既然您有搞定了,那一定可以。
我只有遙控器,我再試試看。再次謝謝您!!
回覆 支持 反對
發表於 2018-1-1 17:12:39 | 顯示全部樓層
遙控器上就有滑鼠功能可以使用,在不同頁面必需交互運用。
回覆 支持 反對
發表於 2018-1-2 08:59:53 | 顯示全部樓層
慘~我的刷死了
開機看到HIMEDIA之後就都一直黑屏
有救嗎?
回覆 支持 反對
發表於 2018-1-2 10:14:30 | 顯示全部樓層
miming 發表於 2018-1-2 08:59
慘~我的刷死了
開機看到HIMEDIA之後就都一直黑屏
用官網的刷應該不會有問題,我也卡過一次
回覆 支持 反對
發表於 2018-1-2 10:15:15 | 顯示全部樓層
longtime 發表於 2018-1-1 14:19
既然您有搞定了,那一定可以。
確定是可以的喔,因為我也設定好了XD
回覆 支持 反對
 樓主| 發表於 2018-1-2 11:01:35 | 顯示全部樓層
慘~我的刷死了
開機看到HIMEDIA之後就都一直黑屏
是在哪一步變磚了,是刷L2N,還是N2N?一般只要固件包刷對了,就不會有問題,找對應的刷機包再強刷看看.
回覆 支持 反對
發表於 2018-1-2 12:26:55 | 顯示全部樓層
謝謝小六大 及Lji大  終於搞定了,嗚呼! 差點沒氣死。
原來 在最右邊  有個remove的圖示只顯露出一咪咪(應該螢幕的關係),沒看見。
回覆 支持 反對
發表於 2018-1-2 18:02:12 | 顯示全部樓層
LJI 發表於 2018-1-2 10:14
用官網的刷應該不會有問題,我也卡過一次
是下載官網的連結.不過當時載到一半有斷線續傳.我再重抓一次試試~
只是一點不懂HMD-2.0.4 2017-07-05.191425 是寫720M
我連結過去是秀File size: 703.72 MB  Uploaded: 2017-08-13 22:50:31
感謝!
回覆 支持 反對
您需要登錄後才可以回文 登錄 | 註冊
地下室改造,我的全套MK電影院 part1(改造篇)
地下室改造,我的全套MK電
幾年前我的第一套劇院系統,是擺在家中2樓的客廳 FOCAL826組成
帶動4K經濟就是要靠這一味,韓國4K UHD頻道強力放送(下載-少女時代L.A演出現場)
帶動4K經濟就是要靠這一味
目前韓國已經擁有5個UHD超高清頻道,分別是:UMAX, CJ E&M
SONY HT-ST5000 令人無言的小缺陷
SONY HT-ST5000 令人無言
小弟我上禮拜購入SONY HT-ST5000 後來在使用上發現當連接的設備
給自已一個幸福甜蜜的家【家訪中壢阿國兄part2】
給自已一個幸福甜蜜的家【
本文章最後由 小許 於 2016-10-23 22:19 編輯 其實這本篇文章
Epson TW7300 vs Optoma UHD 65
我很訝異~ DLP顏色經過調整直逼LCD~ LCD的銳利度直逼DLP~ Eps
